Hello, everyone. I have seen in various places this type of enclosure that is next to the electrical panel. Does that equipment have a circuit interrupter, or is it a disconnect switch with fuses? For what I am seeing it has a circuit interrupter.
IMHO... Hard to tell from the image, but it appears to be either a molded case circuit breaker or a molded case switch.Hello, everyone. I have seen in various places this type of enclosure that is next to the electrical panel. Does that equipment have a circuit interrupter, or is it a disconnect switch with fuses? For what I am seeing it has a circuit interrupter.
Oh, thank you. So, it can serve both purposes, correct? I didn't know that there are moded case switch.IMHO... Hard to tell from the image, but it appears to be either a molded case circuit breaker or a molded case switch.
No... They can not serve both purposes.Oh, thank you. So, it can serve both purposes, correct? I didn't know that there are moded case switch.
They can both serve as a disconnect switch.No... They can not serve both purposes.
