Electron_Sam78
- Palm Bay, FL
Found this the other day... the only thing supporting this 800 amp CB is the conductors
But they are big conductors, aren't they? What's the problem?Found this the other day... the only thing supporting this 800 amp CB is the conductors
Add them where? It may be could have been mounted to the one side wall.how hard would it have been to add 4 bolts? that probably came with the breaker.
I really don't know. Maybe to be able to shut down the MDP it feeds without a transformer outage?Why the breaker?
Both. It's complicatedIs that a utility or customer owned transformer? Definitely a creative way to get a service disconnect without adding a service disconnect enclosure!
Serious problem if there is ever a fault it has to interrupt. Only a hack or a utility who is not going to get inspected could get away with that kind of garbage.
Do utilities ever get inspected?
Too many questions -- what is that dial at the top? --- Orange phase? -- Grounded Conductor? -- What is the piece of eqquipment behind it? --- which side is line/load? --- Could actually be an inspectable install if this is first point of disconnect -- POCO's here are governed not to do work like this.
A thermometer, maybe?Not sure what the dial is.
Look closely, this is the inside of the terminal cabinet of a typical oil filled transformer like POCO's typically use. The dial is either a temperature or pressure indicator of the interior of the transformer enclosure. The conductors leave top of breaker and land on transformer secondary terminals.Too many questions -- what is that dial at the top? --- Orange phase? -- Grounded Conductor? -- What is the piece of eqquipment behind it? --- which side is line/load? --- Could actually be an inspectable install if this is first point of disconnect -- POCO's here are governed not to do work like this.
Not sure what the dial is. Didn't take notice of it. The orange, red and green are from SO cords. The greens are connected to the grounded terminal. The equipment behind it? This is the low voltage side of a utility transformer with the secondary connections behind the CB. Top is line.
YUPoutside tap with So cords ...
