goldstar
- New Jersey
- Electrical Contractor
That's correct. It's weather-proof not water-proofAn in-use type weather cover is not rated for power washing, you say?
Rain tight maybe?
I'll try. This particular GFCI receptacle was on a brick faced wall that was under an overhang and behind a shrub bed. It was protected from most normal weather conditions. The chances of it getting wet from a normal rainfall would be a shot in about 10K. It was intended to power a transformer for landscape lighting so, the cord for that transformer was plugged in and the expandable cover was out. The power washer came too close to the cover and shot the water right at or close to the gasket (which didn't make a perfect seal to the brick). He stopped spraying once the sparks started to fly.I’m having trouble understanding how that damage could be caused solely by a power washer. Can someone educate me?
I'm curious if he also fessed up to causing the damage and paid for it. I have on occasion broken a sprinkler head, or valve, or some drywall. I always get it repaired on my dime.He stopped spraying once the sparks started to fly.
Not sure. I billed my customer. If she wants to back-charge him that’s up to herI'm curious if he also fessed up to causing the damage and paid for it. I have on occasion broken a sprinkler head, or valve, or some drywall. I always get it repaired on my dime.
agree.I guess he was using some chemical additive to clean the brick? I wouldn’t expect plain tap water to initiate sparking.
However I doubt that the installation in this thread is subject to "routine high-pressure spray washing".Exception:
15- and 20-ampere, 125- through 250-volt receptacles installed in a wet location and subject to routine high-pressure spray washing shall be permitted to have an enclosure that is weatherproof when the attachment plug is removed.
Those don't hold out high pressure spray all that well either.Take a look at the exception to 406.9(B)(1).
