H hassaf Member Nov 4, 2008 #1 Does NEC mention requirements regarding j-hooks above non accessible ceiling for low voltage wiring. And, suppose that j-hooks installed above non-accessible ceiling, do you have to install access panels. Do they have to be every 5ft or so?
480sparky Senior Member Location Iowegia Nov 4, 2008 #2 Why would you need access to the support of a cable once it's installed? If it so you can add cabling later, run a raceway instead.
