dpslusser
- Somewhere, USA
I have an application where I need to mount 12 fuses next to each other (see picture below). They are the branch circuit protection from an MCCB.
Since most J type fuse blocks are so huge I wanted to go with fuse holder/studs (see picture below).
My question is that there has to be some type of limit as to how close these fuses can be mounted due to arcing, correct? I have seen some fuse block where phase barriers separate the fuses so they can be mounted closer.
The fuses are 350Amp J type. They are a little over 7 inches in length. Currently they are spaced at 3/8 of an inch.
Let me know what you guys think.
Thanks
Thanks
