JDB3
- San Antonio, Texas
We also require the electrical contractor to provide the service lateral for services larger than 1200 amperes. Since you are doing it, your work must comply with the NEC. If we were doing the work, we would install cables that will carry the expected load. If we are wrong, we will replace the cable at no charge.. . .What size feeders would you recommend? . .
Am I correct that by Table 310.16, 400 AWG with THWN insulation would meet the 320 amp load?
