jeff buckner
New member
- Smyrna, Ga., Cobb Co., USA
I am rewiring an older home and now realize that all the exterior walls are concrete block covered with aluminum siding outside and 1 inch plaster board inside. The inspector told me to run all wire in compliance with NEC 2014 standards. Since some circuits and switch legs will need to pass through the hollow cells of the blocks, 4 or 5 feet into the attic, should these circuits be protected from the rough edges of the concrete block in conduit.
