Jenn-air Range
ashtrak
Maryland
Need to Run a circuit for a Jenn-Air Range. The name plate says 20 amps for this particular model (combination gas and Elec.) The instruction book says 30 a circuit. The 50amp cord is already connected. I called customer service and and they didn't have any KW rating listed. Was wondering if anyone had run a circuit for one of these combo's. I guess #10 is ok? I'd be more comfortable with a KW rating. Thanks
The jenn-air unit I have requires 50 amp 240v. It has a gas cook top and two ovens, one twice the size as the other. If I remember, the book was very vague. Jenn-air's customer service # is 1-800-688-1100
If the instruction manual does indeed apply to the unit you have, I would go with a 30 amp circuit with a 50 amp receptacle.
