Job security
rich000
Harry Homeowner asks: "Can you give me a quote on a panel replacement? I heard that Federal Pacific panels are bad. I also can't find breakers to power up my new circuit I just ran."
I bet that panel is in a garage, seen that before
prolly has a 1-2-3 Wiring book from home depot sittin under the panel
I've seen worse. In a home. Romex run on wall and then punched back in like in the pic. Exact replacement breakers couldn't be found so someone found some that would fit. One 240 v breaker actually burnt in half and was arcing to the point of making noise when I got there. Breaker came out in pieces. Below me in the basement was a 500 gallon drum with about 300 gallons of heating oil in it, leaking all over.
