textmi
- California
- EC
I have (2) branch conduits serving (2) pieces HVAC equipment in the the same location fed from the same panel. We are now adding replacing the two units with (1) unit that is more sensitive to voltage drops and is having issues with errors and shutdowns. The original branch conductors are not sized to provide less than 5% total voltage drop recommended by NEC although the equipment manufacturer allows up to +-10%.
Is it allowable to use join the two separate branch conduits to feed (1) piece of equipment using (1) OCPD to reduce the voltage drop?
