Junction box covers with KO as a means of device support?
two-bit
Minnesota
Engineer
Can you use a junction box cover with a knockout as a mounting mechanism for a water heater timer?
I am looking at the installation guide for a water heater timer that that instructs installers to mount a 4 square box (opening up) to the top of the water heater, then mount the timer to a box cover with knockout by the nipple on the bottom of the timer. The nipple is the only means of support for the device which sits atop the box.
While I can't find any code reference that specifically calls this out, it's a flimsy installation and seems kind of shoddy.
Anyone seen this before or know how it's justified (or not)?
Thanks!
Sounds similar to how some doorbell transformers are mounted. I don’t see an issue, especially since it’s part of the manufacturer’s instructions.
I can't share the picture because it's copyrighted material. But the knock out in the box cover is the only support and the device is much larger than the 4 square box.
Doorbell transformers, I've always attached them to a KO in the side of the handy box, not the removable cover.
