Junction box w/terminals blocks class 1 div 1
killer76
I have an application in a CL. 1 Div. 1 Gr. C,D area, in a enclosure I only have one strip on terminal blocks
as the terminal are not arcing or sparking devise
would a NEMA 4X enclosure be permitted or would I need an NEMA 7 enclosure with seals
I understand that the enclosure must be rated for the area classification is this the reason to install a NEMA 7 enclosure only
and were in the code would I find this information if a NEMA 7 enclosure is required for terminal blocks
I realize that the AHJ would have final decision
thanks
Re: Junction box w/terminals blocks class 1 div 1
You just answered your own question. The wiring method has to be rated for the area classification.
ok with that understood it is the area classification requirements,
so will the enclosure need to have seals installed
thanks
... so will the enclosure need to have seals installed ...
If it were only as simple as that.
Yes, you could use a NEMA 7 (indoor) box and Seal-offs.
But that might be overkill ($$$) if your wires are for Intrinsically Safe devices and you have I.S. barriers / Isolators (and seal-off at the correct Safe Area /C1D1 junction) in a control room.
Or if your wires are between a simple RTD device and it's transmitter, again, nothing more than a box rated for the environment, not hazardous area rating, might be used.
But if they are for something like a 5HP motor, then I'd say the NEMA 7 box & seals may be needed.
So, please tell us what signals (devices)/voltage/amps the wires attached to the terminals are and any seal-offs / conduit / etc that are planned/used.
BTW: There is a "Hazardous (Classified) Locations" forum here.
in the shelter is a vent fan, a receptacle and an exterior light and interior light, all 120v 20 amp max
the j-box is just a termination point for field connection,
so with no acring or sparking device would i classifiy this as nonincendive devise
it may be best to just add seals, I just wanted to find this in the code were it identifies terminal blocks in this type of application
again I see the block as non arcing or sparking
I know this is done in a class 1 div 2 classification just cant remember the guide in cl 1 div 1
thanks
killer76,
The junction box is just that,a junction box,the terminal blocks inside of it have no more bearing on the situation than wirenuts do.
so what you are telling me is that seals are required on the enclosure,
can someone tell me were to find this in the code
thanks
The box must be rated for Class 1 Division 1 [501.10(A)(3)] and seals are not required unless the raceway size is 2" or larger. [501.15(A)(1).
Don
See 501.15 (A).
If the box has arcing/sparking devices within it, or has conduits larger than 2" entering it, then seals are required.
The box is required to be approved for Cl 1 Div 1 per 501.10 (A)(3).
