Jurisdiction Over High Voltage Services
sii
Nebraska
I’ve never thought about this before and am now only because someone I know is going to work at a facility that has a high voltage service. Who has jurisdiction, as in who inspects the installation of a high voltage service?
In Nebraska, the state is the AHJ with exception of a few of the larger cities. I doubt the State would, and I know the cities don’t have the knowledge to inspect a 13,000 volt service.
The NEC also doesn’t cover anything over 600 volts, would the installation have to conform to NESC rules?
The NEC does cover voltages higher than 600V.
In our state the normal AHJ performs inspections of the higher voltages, up to 34.5kV found on campus and industrial installations.
The NEC does not do a very good job with medium voltage installations....they are taking a start at changing that in the 2023 code with new medium voltage articles.
In almost all case the medium voltage systems are engineered systems and a number of AHJs inspect to the design, or hire a person more qualified in medium voltage work for those inspections.
It seems to me that the NEC would be better off just saying it should be an engineered system and not trying to put in a bunch of design criteria into the code like they messed up the rest of the code with.
