dcspector
- Burke, Virginia
I have a situation in a hi rise condo building. MHP series Magic-Pak self contained heat pump units are installed. These units are electric strip 5kw to 7kw. the name plate ratings show min.ckt. ampacity at 38 amps. The EC ran 8wire with a 40 amp 2p ocpd on....no problem. The name plate rating only shows max. fuse/ brkr at 20 amps. I am confused. At 5000w at 208v is 24 amps.....Note..the only thing mentioned on the nameplate for max. ocpd is 20 amps.
