joeyww12000
- Chatsworth GA
From the utility transformer pad we pulled 4 runs of 4 size 500 Aluminum, A B C N in 4 seperate PVC conduits. In the switchgear copper GEC's to ground rod, building steel, rebar in footer and copper water pipe. The GEC's to ground rod and rebar in footers are 1/0 which is correct for size 500 service entrance conductors. The GEC's to building steel and water piping was smaller guage maybe a #1 I could not tell clearly, I just know it wasnt 1/0. Shouldnt all GEC's on supply side be the same size? Also would the fact that the service conductors were run in parallel change the GEC size?
