knot stable
- Warren,RI
Residential setting single family home; 4/0 SEU cable to 200A meter socket with 200 main. GEC and grounding electrodes ok(this becomes your service) 4/0 SER cable to 200A MLO panel 42circuit. (factory single lugs removed,double lugs installed on site).From the double lug; another 4/0 SER to the original 42 circuit 200A panel.(with all homes electric heat connected to) Sub cable wired in properly. First panel has 2 ground bars connected with the jumper to each connected. Grounding and ground wires connected to each bar. (Wrong)
What if any is the ruling on doing this, 2-200A panel on one 200A main and the factory lugs removed and doulbles installed. Of coures the grounding and grounds must be seperated.
