Low-budget distribution panel:
... you wanted to hang a chained fixture in the panel, this one is ready for it.
they forgot to make linkage that will operate the switch on power strip with the external handle![]()
I immediately thought that the person mounting that box needed one more toggle bolt, but didn’t want to go to the hardware store just for that. So they found an old plant hook with one on it, but couldn’t remove the hook so they just used it with it. I’ve done stuff like that... but usually I’ll go back and clean it up later.
That power strip in an old disconnect connect box is a classic too. I especially love how they pigtailed zip-cord plugs onto the ends of NM cable, no grounds connected to anything.
If they had thought that through better, they could have mounted the strip so that the old disconnect bar would hit the switch just right to operate it.Maybe not though.
When they painted the power strip green did that void its listing?![]()
No; green is "required" for outdoor use.![]()
This high quality wiring reminds me of the time when I was on a "behind the scenes" tour at UL's Northbrook, IL headquarters. On one bench they had a setup that used solenoids to repetitively test some device, but the wiring was just a hay-wired mess of THWN connected to an open breaker panel. When a coworker mentioned that this didn't look UL approved, I corrected him by reminding him of where we were, and that "by definition" it must be UL approved. He didn't argue with that.![]()
