mdshunk
- Right here.
Because I'm always looking for low-cost ways to improve the perception of value, I painted some panel backboards today to use during service changes. As I expected, they'd be downright expensive. From one sheet of plywood, I cut two at 24x48 and three at 24x32.
The backboards cost out as follows:
That brings the total real costs before markup at $21.81 per 200 amp backboard and $14.54 per 100 amp backboard. They'll end up being pretty expensive, but they might be good tasks for "fill in" work for a guy needing to fill an hour at the end of the day who you might otherwise let go home with a full day's pay or who might just chat up the office girls.
- Sheet of 23/32" Plywood, $20.88. That's $5.22 for each 200 amp backboard, and $3.48 for each 100 amp backboard.
- Paint was 23.74 for a gallon, and one quart exactly does three coats on all 5 backboards that you get from one sheet (2 front, 1 back). That's $1.48 in paint for the 200 amp backboard, and $.99 in paint for the 100 amp backboard.
- It takes 21 minutes to paint all three coats on each 200 amp backboard at 7 minutes per coat. Using a total real labor cost of $41.00/hour, it costs $12.30 to paint each 200 amp backboard.
- It takes 12 minutes to paint all three coats on each 100 amp backboard at 4 minutes per coat. Using labor data from the line above, it costs $8.20 to paint each 100 amp backboard.
- It takes 5 minutes to clean up between each of the three coats. Using labor data from above, it costs $2.56 per 200 amp backboard and $1.70 per 100 amp backboard for clean up tasks (washing out brush).
- I guessed at brush wear, and ascribed $.25 per 200 amp backboard and $.17 per 100 amp backboard.
