Just some humor for the day.
khixxx
BF PA
For everyone who has ever had or given an evaluation - just remember, it could have been worse. These are actual quotes taken from Federal Government employee performance evaluations.
1. "Since my last report, this employee has reached rock-bottom and has started to dig."
2. "I would not allow this employee to breed."
3. "This employee is really not so much of a has-been, but more of a definite won't be."
4. "Works well when under constant supervision and cornered like a rat in a trap."
5. "When she opens her mouth, it seems that it is only to change feet."
6. "This young lady has delusions of adequacy."
7. "He sets low personal standards and then consistently fails to achieve them."
8. "This employee is depriving a village somewhere of an idiot."
9. "This employee should go far, and the sooner he starts, the better."
10. "Got a full 6-pack, but lacks the plastic thingy to hold it all together."
11. "A gross ignoramus -- 144 times worse than an ordinary ignoramus."
12. "He doesn't have ulcers, but he's a carrier."
13. "He's been working with glue too much."
14. "He would argue with a signpost."
15. "He brings a lot of joy whenever he leaves the room."
16. "When his IQ reaches 50, he should sell."
17. "If you see two people talking and one looks bored, he's the other one."
18. "A photographic memory but with the lens cover glued on."
19. "A prime candidate for natural de-selection."
20. "Donated his brain to science before he was done using it."
21. "Gates are down, the lights are flashing, but the train isn't coming."
22. "He's got two brains cells, one is lost and the other is out looking for it."
23. "If he were any more stupid, he'd have to be watered twice a week."
24. "If you give him a penny for his thoughts, you'd get change."
25. "If you stand close enough to him, you can hear the ocean."
26. "It's hard to believe he beat out 1,000,000 other sperm."
27. "One neuron short of a synapse."
28. "Some drink from the fountain of knowledge; he only gargled."
29. "Takes him 2 hours to watch '60-Minutes'."
30. "The wheel is turning, but the hamster is dead."
realolman
This has nothing to do with anything but I thought it might fit the topic.
SKILL SAW: A portable cutting tool used to make studs too short.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted part which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, ''What the...??''
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles with the speed of a ballistic missile for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2 X 4: Used for levering an automobile upward off of a trapped hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent to the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic
parts. Especially useful for slicing work clothes, but only while wearing them.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling ''DAMMIT'' at the top of your lungs. It is also, most often, the next tool that you will need.
frizbeedog
Oregon
Those are great.
And very true...................:smile::)
While those are funny and had me rolling on the floor, they reek of unprofessionalism....on the part of the evaluator. I can only hope that the persons writing those type of comments in an evaluation were themselves taken to task for doing so.
It's not really functional or productive for an evaluation.
...but dang funny.
khixxx
BF PA
...but dang funny.
I tell everyone it is geared towards congress, as we the people have evaluated them :)
if you guys want a laugh You Tube is full of stuff. Type in "Maze Game" for your search. some are ok but others will bring tears to your eyes, but I am easily amused :)
