Re: just starting out
You need to figure material and labor for each item type. Like $20per single pole switch $xx per duplex recept,price out dedicated items, service .
I use 1/4 hour per rough on recept or switch, light outlet.I use 5 min to trim switch or recept.Light fixtures can be tricky but 20 min to trim should average out.Material will be easy to figure,labor is local issue.Whatever you do don't take the job for a number your nervous at.Bottom line you need to make money and things seldom go easier than planned
Would use sq ft to double ck your bid,but that could be off 20% real easy.
How much per item depends mostly on your labor cost.
[ January 22, 2004, 10:20 PM: Message edited by: jimwalker ]
