Natfuelbilll
Any information (Standards, Codes, Recommendations, Outage data, etc.) available that can justify data center electrical preventive maintenance?
They needto do a cost analysis of an unplanned outage due to a breaker not transferring from normal to standby mode?Any information (Standards, Codes, Recommendations, Outage data, etc.) available that can justify data center electrical preventive maintenance?
Sounds like the poster knows that you have to convince the owner that it's cheaper to fix it before it breaks then when it breaks, but as for sources to help prove that point.
What services are you providing? Infrared camera imaging? Backup Generator testing? Load testing? UPS battery Maintainance?
Try googleing data center preventive maintenance
You'll get lots of hits- filter though it. Below was one of the first ones I saw-
http://www.comnews.com/wp_library/APC_whitepaper.pdf
My questions go beyond routine testing inspections as these are being completed on UPS and generators.
What is the value of shutting off equipment and physically inspecting wiring terminations and connections on power, controls and communications? Any good data out there?
How complete of a PM can be made without de-energizing and "shutting down the data center"?
IR is being considered. What problems won't IR pickup? I know some circuits are either "spared" or lightly loaded. Is adding temporary load a recommended means of uncovering problems on those lightly loaded circuits?
What types of specs or PM scopes do monster (IBM, GM, Microsoft, Goog, US Government, Los Alamos, etc.) companies follow?
How much of NFPA 70B... (I don't have my copy this morning)... is done live .vs. de-energized?
Dec 18 09:48:01 bigip2 system_check[1760]: 010d0006:0: Chassis power supply 102 is not supplying power (status: 0): make sure it is plugged in.
