I have a tytpe T thermocouple that is used to connect to the device under test (DUT) inside of an environmental test chamber. The temperature inside of the chamber can be between -70 to 190 C. The thermocouple wire is shielded. If I connect the non sensing end of the shield to ground, i have to clip the shield on the sensing end. My concern here is that the clipped shield on the sensing end can make contact with metal inside of the chamber causing ground loops.
Would I be better off just not grounding the non-sensing end, and just insulate it? The sensing end would be trimmed, but due to the conditions inside the chamber it is difficult to completely insulate the trimmed portion of the shield. What are the risks of having a shielded wire on a T/C and simply not using it?
I could continue to ground the non-sensing end, and use Kapton tape to insulate the shield at the sensing end of the cable. My concern here is that since the sensing end will be connected/disconnected multiple times to the DUT, that the tape will become disformed over time or fall off and require servicing just to re-apply the kapton tape.
Any opinions in regards to not grounding the shield vs grounding the sensing end of the shield and using kapton tape to insulate the shield on the non sensing end will be appreciated.
