im sorry i forgot to list name plate volts. it is 400 volts 50 hz 2 speed single winding.Ok. I assume dual voltage and the kw is the output at the voltages.
12 lead connections are there in the fourth and fifth page
That's cool. Thanx.This should get you there
those pages only list 6 lead connections. i am assuming that i have a motor that should be constant torque. name plate shows 4/2 then under that it has Y/D/Y/YY.That's cool. Thanx.![]()
yes but those are single speed conn. the way i see the name plate i have a single delta 4 pole and a 2 Y 2 pole conn. I have never seen a single winding 2 speed like this. customer says 12 leads coming to the motor. been doing this for 22 years.Scroll down. Pages four and five are for 12 lead.
Dahlander connection?yes but those are single speed conn. the way i see the name plate i have a single delta 4 pole and a 2 Y 2 pole conn. I have never seen a single winding 2 speed like this. customer says 12 leads coming to the motor. been doing this for 22 years.
Katt is now owned by weg. weg rep said it could take weeks to get answer from katt.The other thing to be careful with is that especially on this exotic of a motor they might not follow the standard either. Best to contact the manufacturer.
Good example is Toshiba. They have some “gotchas” on their wiring standard that will burn you if you just follow the standards. Also two speed motors are tricky in the first place because there are so many variations.
It’s a pole changing two speed?
I thought those were 6lead...![]()
That’s what I’m wondering. I keep going back and thinking about Post #9.Normally 6.
I wonder if this is a 2 speed, wye-delta? It’s a European voltage and over there, Y-D is very common.
Is it possible it is a two speed consequent pole motor?yes but those are single speed conn. the way i see the name plate i have a single delta 4 pole and a 2 Y 2 pole conn. I have never seen a single winding 2 speed like this. customer says 12 leads coming to the motor. been doing this for 22 years.
ok. so how should i number my winding. motor is a 36 slot 36 coils . 6 coil groups with all leads going out to t box.
Take a pic of the data plate and post it here.ok. so how should i number my winding. motor is a 36 slot 36 coils . 6 coil groups with all leads going out to t box.
Its a Katt brand of motor . german made 50 hz name plateNormally 6.
