Isn't kilowatt hour using time twice.
What? Because a watt/second is a joule?
Watt/hour isn't a joule. But it is 3600 joules. You can make a kilowatt hour out of that by multiplying it by 1000.
You could say the same thing about miles per hour. 2580'/hour.
0.7166'/Second.
I didn't even read the whole thread but check out what happens with E=MC squared.
(energy)=(Mass) Times (the speed of light) squared.
The speed of light is 186,000 miles per second or 300,000,000 meters per second.
In the equation E=MC squared, you have to realize that velocity is distance divided by time.
This celibrated equation forces us to realize that time has at least two dimensions.
The reason is that "C" (the speed of light) already has a time component, (distance/time) now, because that is squared, time has at least two dimensions. It's an area.
You can use time twice. And far more.
By the way, you're not using time twice in this case, only changing it's unit of measure.
I know. :grin: I couldn't help it.
