We have six loop feed transformers that are fed from a Main-tie-Main MV switchgear. The loop shall be kept open all the time, otherwise it will be a big accident when two services form different substations seeing each other. The loop feed transformers are using loop feed T-blade switches. So one of the T-blade switches shall be able to be locked at open position. Have you guys used Kirk-key interlock for this application? Any info is welcome. Thanks.
