Re: kitchen micro
David: I believe that you did not disagree. Or perhaps I should say, your description did not contradict my description. We have here another example of the English language getting in the way of communication. The difference here is between saying ?a small appliance circuit? and ?the required two small appliance circuits.?
Obviously, a microwave is a ?small appliance.? I agree that a circuit that feeds a microwave can be properly called ?a small appliance circuit.? We all know that the NEC requires a residence to have two 20 amp ?small appliance circuits? serving the kitchen space.
What I believe Pierre said, and what I agreed with, is that the microwave does not need to be powered by one of the two required ?small appliance circuits.? It can be powered by a third circuit, independent from the required two. You can have a circuit that supplies only the fridge, another circuit that supplies only the dishwasher, another circuit that supplies only the garbage disposal, and another circuit that supplies only the microwave, but you will still need two separate 20 amp circuits for small appliances. Therefore, if a 15 amp circuit is sufficient for the load of a microwave, then the fact that a microwave is a ?small appliance? would not prevent us from installing a 15 amp circuit. But if the receptacle is above the countertop, it will still have to be GFCI protected per 210.8(A)(6).
