Kitchen reno w/ limited breaker space
Therossinator
New User
Ventura, CA
Civil Engineer
I currently have four circuits feeding my kitchen: two SABC (MWBC), a dishwasher, and garbage disposer (MWBC). My current circuit breakers are basic GE "thin" breakers and upgrading to AFCI or GFCI would take up twice as much room. I have a 8 space/16 circuit panel I only have 3 open spaces (6 circuits) and would like to keep as much open capacity as I can in as I plan to add a dedicated circuit for all-in-one ventless laundry machine and eventually a car charger.
due to moving/adding outlets, I plan to replace the circuit breakers for the SABCs with AFCI/GFCI breakers but leave the dishwasher and garbage disposer breakers as is as I am not modifying those circuits. They already have GFCI receptacles.
I plan to move the refrigerator and this new location will require a new receptacle. Will this need to be a dedicated circuit or can I use a SABC?
I plan to replace the hood above the gas range with a hood/microwave combo. Will this need a dedicated circuit or can I use a SABC?
If a dedicated circuit is required for either the refrigerator or the hood/microwave combo, would an AFCI/GFCI receptacle meet the requirement or would the circuit breaker need to provide that protection? If a receptacle is acceptable, could I use a duplex AFCI/GFCI receptacle or because it's a dedicated circuit would I be required to use a single receptacle (hooked up to something like a Leviton AGRBF-W)?
I know that the obvious solution would be to get a bigger panel, but my current one is not a standard size (condo built in the 70s) and doesn't span the width between two studs. The stud that it's not attached to is adjacent to a wall so if I were to get a new panel, I believe that the overlap of the dead front would hit up against that wall.
Thank, all!
Unfortunately the forum rules do not allow us to assist in DIY projects.
This site is designed for:
  • Electrical Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC� Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
