I am installing a kitchenette in a basement studio apartment. The kitchenette is fed by a single 10/3 NM cable which originates in a subpanel that is dedicated to the basement apartment. I would like the kitchenette to have 3 or 4 seperate 15 or 20 A circuits for small apliances, mini hot water heater and a small refrigerator. I would like to do this by feeding a small subpanel with the 10/3 cable, and running my individual circuits with 12/2 and seperate breakers. The only convenient location to install this panel is directly above the sink. Is this permitted under NEC? I know that panels are not permitted in bathrooms. If it is permitted, does the entire panel need to be fed by a GFCI double pole breaker? Or may I simply use GFCI outlets like a normal kitchen setup? Finally, because the kitchenette will be part of a small 12 by 12 room, do all of the outlets in the room need to be GFCI? I am assuming "yes" because NEC would consider the whole room to be a kitchen.
Your reply is appreciated
Glenn
Glenn
