The attached image shows a exhaust fan viewed from inside the kitchen. The ouside has a hinged door that opens and operates the fan by pull chain. When I open unit there were two wires inside fan housing not connected to any thing. I suspect they were connected to the pull chain switch. but I did not see any switch inside. The homeowner say it use to work and they did not open unit. I plugged fan into 110V temporary and it works, so its a matter of how is it switched by releasing chain that opens outside hinged door?
