Kitchenette has same code as kitchens ?
The NEC defines a kitchen as "an area with a sink and permanent provisions for food preparation and cooking." If it's got a sink and a microwave, even, most AHJs would consider it a kitchen.
As long as the microwave was a built-in, otherwise it's not permanent.
I could see trying to avoid the kitchen requirements in a commercial setting, but for a residential kitchenette, why not build it like a kitchen? I could easily see the homeowner wanting to plug in a bunch of crock pots, roasters, fryers, etc. during a party. Two countertop circuits might not be enough.
There are no circuit requirements for a non-residential kitchen. That is a design issue and not a code issue.
While there's no small appliance circuit requirement, it should be noted that receptacles in non-dwelling kitchens need GFCI protection (countertop or elsewhere).
If your asking me to play AHJ, if you have to undo a screw or break a union, it's permanent. Pull a plug and go, not permanent.
Exactly. If it is meant for the end-user to disconnect and relocate, or put away on a regular basis, that would be non-permanent. If you have to get a tool to disassemble its connection to the building/plumbing/electrical, or if you have to cut through building materials to remove it, that would be permanent.
Sure a permanent appliance isn't truly permanent in the sense that it can still malfunction years later thus needing replacement, or be removed during a remodel. However, it is permanent in the sense that it is built-in as part of the building, rather than being a stand-alone appliance that anyone can unplug and move.
That makes sense. I’ve always considered a stove “permanent“..
and after years of sitting there with years of spills you would think some are permanent while trying to get them out for replacement...
Electric stove, so you only unplug it to move it. So I guess I don't need the small appliance branch circuits in my "non-kitchen" area. :)
Many of the commercial kitchens I wire have quick-disconnect gas fittings; as quick and easy as unplugging a plug.
