iwirehouses
3 different questions, this might be illegal to do in this forum but here it goes...
1. I understand in a kitchen, GFCI's are need over the counter top. This is great for the sink, but what if there are 2 more counter tops that don't connect and an island in the middle, all sinkless. Duplex receptacle them?
2. Say your running juice to a shed 300 feet away. 20 amps out there tells me to use 8 ga. due to voltage drop. Ok, when all is said and done, how would one wire the shed with 8ga? I am assuming wire the shed with 12ga and feed it with 8ga, correct? Ok, say its going to a cheap 15amp 120v cord connected pool pump. 1 15amp GFCI receptecle. Do I pigtail 14ga. onto the 8 ga. right behind the outlet then tap into the outlet?
3. Last but not least. My life's question. And I have searched the book for this with no answer. What can you use in conduit? Since the beginning, every electrician has told me when using conduit, indoor or outdoor, always pull THHN. You can't even use UF. Then, my teacher told me, you can use anything, even romex provided its not outside. He's the first person I ever heard say this. What can you use in conduit besides THHN? What about wiremold?
Thanks guys
Thanks guys
