Knob and Tube circuit question.
Outlets in bedroom not working, fluke meter reads 61 volts, second meter reads 57 volts both digital. Ideal solenoid meter does not read, 110 volt test light does not light, 24 volt test light does not light. Fluke and ideal inductive test sticks do light up and buzz. All meters and lights checked out good on 120 circuit before testing.
I think that the grounded wire is open in the wall or ceilings I checked some J- boxes but could not find the problem. The grounded wire is tight at the outlets and the panel. I suggested running a new circuit and grounded outlets.
What do you think?
What do you think?
