bulldog195169
new scenerio. older house wired originally with knob and tube. over the years new wiring has been spiced in, knob and tube in attic has been covered with insulation, and a short in the attic has brought the electical inspector to the home. the questions is... does the knob and tube portion have to be removed now that it has been altered and covered or since it is preexisting do you have only the damaged area replaced. knob and tube in basement has been spliced into (no junction boxes. the service panel has been upgraded from 60 amp buss fuses to 100 amp breakers. does the nec regs provide guidelines for requirements when two different wiring methods have been mingled together?
