618electrician
- St. Louis
- Maintenance electrician
by the nec 2020 is nob and tube legal in your house if not covered with insulation. /// ////////////////////////////////////////////////////////////////////////////
Most of the issue with the old aluminum was related to the excessive cold flow and temperature related expansion and contraction of the alloy used in the past. All building wire made since the mid 70s uses the 8800 series alloys, and perform much better.K&T was a big one about 10 years ago, frankly I see alot of it and if its untouuched I dont see any issue personally. and when did they quit using it 1930? only so may existing homes can have it,
aluminum wiring on the other hand is much more of a snag it is still common for 30 - 50 amp circuits many policies exclude it with a waiver.
I actually had a friend call he thought he had aluminum wiring, what he saw was tinned copper, when I looked over his attic I told him no that's not aluminum garbage you have good quality knob and tube it will last forever! (Just take that penny out from behind the 30A fuse and use a 15A fuse LOL)
Have you seen any that wasn't modified, spliced or added to, or covered in insulation post when it was commonly used? I haven't.Knob and Tube would be grandfathered in. If it was legal when installed, it would be legal now. Modifications to it may bring up some issues and local codes along with insurance coverage may add pressure to update. YMMV.
Yes, I have, several but I'm old and some were high end homes. The had dimes instead of pennies in the fuse holders.Have you seen any that wasn't modified, spliced or added to, or covered in insulation post when it was commonly used? I haven't.
I still have seen the other stuff sold at the supply house here, URD for services, then people use the leftover to tail from meters to main panel.All building wire made since the mid 70s uses the 8800 series alloys, and perform much better.
Agree. How many houses have blown in insulation in the walls etc. Most of themHave you seen any that wasn't modified, spliced or added to, or covered in insulation post when it was commonly used? I haven't.
My brother worked for company that insulated homes. Enough fires immediately after that ceilings had to have K&T removed/ disconnected. Walls were not blown.Agree. How many houses have blown in insulation in the walls etc. Most of them
