Jim W in Tampa
- Tampa Florida
tallgirl said:Cool. I've seen houses that I know were wired with K&T, but I've never seen the walls off of one.
Out of curiousity, what's the outside diameter on the tubes? I assume the studs are 2" by 4" (not to be confused with 2x4's), and by eyeball those are pretty fat wires. If I whack the tubes with a hammer, will they shatter and then I could run 12/2 or 12/3 Romex through the nice little holes?
I would just pull the tube out (aprox 1/2 inch) and use the hole.If no insulation in the walls rewiring is not that hard.Use as many junction boxes as you need to keep wire pulling to a min..Back switching might help.Each house is differant so just gotta check them out to see what will work.
