Knob & Tube Wiring Again (sorry)
goldstar
New Jersey
Electrical Contractor
I know many insurance companies now want ALL active K&T wiring removed from a house or they won't insure it. However, somewhere during my many years I remember taking a CEU course where it was mentioned that it was acceptable to install a GFCI ahead of all K&T wiring providing you mark the receptacle(s) with a "no equipment ground" label. I don't remember if it was an NEC rule or a NJ Rehab Code rule. Is anyone familiar with this and if so, can you give me a reference ?
OR
Was I dreaming about this :?:p
Any answer is acceptable.
OR
406.4 (D)(2)b&c are the NEC articles that permit you to replace an old 2 wire receptacle w/ gfci.
You are recalling a NEC rule that has been in existence for decades.
The basic nub is that one can install grounding type receptacle devices at existing outlets on an ungrounded wiring method IF the grounding type devices are labeled NO EQUIPMENT GROUND at each device and they are protected by GFCI protection. Also remember that the act of replacing the receptacle device also triggers the need for AFCI and TR at each device replaced. If one is in for a part of 406.4(D), one is in for all of it.
In your case, if one simply puts GFI protection at the overcurrent protection for a K&T branch circuit, one may not need to do any labeling of devices if they are all legacy two-wire nongrounding type.
Ultimately, whether that will satisfy a particular insurance carrier's policy restrictions is an issue outside of the NEC.
That would not be true in NJ.
I work in a State that adopted the NEC without modification. Are you referencing a NJ amendment?
Even without amendment, the NEC says you don't have to bring existing installations up to the current code and 210.12 only kicks in if you replace, modify, or extend the circuit. Replacing a receptacle is not one of those. And yes, NJ has a rehab code that would otherwise nullify the requirement, although if you were extending a circuit into new construction you would probably have to go AFCI.
Actually, you will find, for the first time, in the 2014 NEC, that an additional requirement beyond 210.12 exists in 406.4(D), specifically 406.4(D)(4). The arc fault protection may come from an AFCI receptacle. The 2017 NEC continues the 406.4(D)(4) AFCI requirement.
I have no experience with the language of New Jersey's rehab code, so I accept what you say as so.
Yes. Thank you. I found that but I was almost certain there was specific verbiage in the NJ Rehab Code regarding this. In the case I have coming up the HO wants to sell her house but the buyers' insurance company will not insure the house if it has K&T. That said, I'm just trying to offer a quick remedy to make the house safe for sale. Irrespective of what my remedy may be, insurance companies are not required to insure your house if it has K&T.
I haven't been there yet so I don't know what I'll run into. From my experience in these older homes typically where K&T is present there is or was a fuse panel. I'll post what I find. I've worked in several older houses in the Glen Rock and Ridgewood, NJ area where I had to literally cut out a channel of plaster and wood lath in a 1st floor hallway to replace K&T. In some cases, if the basement isn't finished replacement is somewhat easy. Getting to second and third floors becomes complicated. I wonder what EC's do in historical homes where walls and ceilings have to remain as original as possible.
I'm not trying to high-jack this post. Does anyone know of insurance companies allowing K&T to stay if it is arc-fault protected at the panel?
PS. Although arcfault protection is a great idea, I'm not sold on the fact that the existing AFCI devices actually do what they are supposed to do.
Regardless of codes, GFCI, AFCI, etc. an insurance company is free to object to having any K &T in something they provide coverage for if that is what they want. Your choices are to comply with their request or seek coverage elsewhere. If someone else will provide coverage, you may not get as good of a rate as you might if you didn't have k &T wiring though
. . . you may not get as good of a rate as you might if you didn't have k &T wiring though
Compared to what?
The replacement of a core wiring method of K&T can run well beyond $10,000, including collateral damage repair and finishing. And the more ornate the Victorian accents, the higher the final cost. All to avoid, what, a $100 per year adder to include K&T, and letting go of a "loyalty" to an insurance agent (or agency or company name)?
Given that there are many millions of dwellings with core wiring from first electrification in the early 1900s all over this country, and most all of them are insured. . . the question really is why one would even put up with the petty tyranny of an insurer based ban on K&T.
Compared to what?
Is kind of what I was getting at. If one company won't insure it, another one might. Don't expect same rate, it could happen but doesn't have to happen. If you have a loan, the loan provider may come into play as well, but usually leave this sort of issue up to insurance providers, and don't care as long as any potential loss will be covered.
I've heard of some insurance companies in our area refusing coverage of homes built pre- WW2 that still have galvanized water piping. They are saying that the design life of the pipes is 75 years.
Maybe if the house has K&T and galvanized pipe, it will cancel out because the burst pipe will extinguish the electrical fire. LOL
Are insurance companies really looking that closely at the electrical wiring in homes nowadays?
Unfortunately for HO's - yes they are. Fortunately for us EC's it's more work but it's dirty work.
Frankly, I suspect this really is related to certain policy / plans that are sold for lower risk structures and the insurance agent or company is saying that the risk exposure is different for a different structure and the additional risk exposure is something they want to be paid for.
Some agents or insurance companies are interested in only cherry picking the highest profit margin (lowest risk) situations to extend their coverage to, and nothing more.
An insurer profit motive should absolutely not be construed as a blanket finding of "high" risk. There is good reason that K&T is still in the NEC, in my opinion.
how are they to know what's within wall cavities?
I think it does vary. I haven't tried to insure an old house so can't really say, but do occasionally hear about someone that can't get insurance (at least from a specific provider) unless they make some changes, and not always just for electrical issues.
