chevyx92
- VA BCH, VA
Will a regular knockout set cut through stainless back splash like you see in commercial kitchens??
Hydraulic might, but you may not cut anything else.
bi-metal hole saw, but if you look for Tungsten Carbide Tipped it will be faster and cleaner over standard one.
So true. Painfully slow and every bit of patience that can be mustered.I use an extremely slow speed and coolant if available. I believe that by using too fast of a speed the heat generated at the end of the cutting tip actually hardens a SS and intern dulls the cutting edge. So be very, very patient and allow the holesaw to cut.
I use a regular Klein set to knockout stainless as long as it isn't too thick. Over 16ga I will use hole saws...just regular saws, slow feed, lots of lube. The SS will kill your
knockouts but they do work. Put lube on those too.
Drill slow LOTS of HEAVY pressure
And the kind you use can make a big difference.Pack hole saw with ductseal to help keep it cool, still need cutting oil though.
Does that really work? It would seem to me it would just insulate the inside portion of the holesaw and inhibit any natural cooling.
Maybe you need to pack it with dry ice![]()
I thought it worked, assumed duct seal getting warm meant holesaw was warming slower, but since you asked if it works, I can't prove that it does. I felt like my holesaws were lasting longer when I started packing with duct seal but have no statistics to back up with.Does that really work? It would seem to me it would just insulate the inside portion of the holesaw and inhibit any natural cooling.
But for sealing, the purpose is usually to keep moisture (and/or heated or cooled air) from passing through the hole. Its insulating qualities are not really important for that.Maybe you use super heat conductive duct seal of some kind. It would make sense to pack it with something that is a good conductor of heat to sink some of the heat, but I wouldn't think your typical "duct seal" is a very good heat conductor, and for good reason when sealing raceways with different temperatures on each side.
We punch holes in stainless steel kitchen hoods all the time. We use Greenlee punches. Never had a problem. Drilling the pilot hole, that's another story. Slow speed, high pressure and keep it lubed. I used Breakfree CLP with good success.
