110.12(A) Unused Openings. Unused openings, other than those intended for the operation of equipment, those intended for
mounting purposes, or those permitted as part of the design for listed equipment, shall be closed to afford protection
substantially equivalent to the wall of the equipment. Where metallic plugs or plates are used with nonmetallic
enclosures, they shall be recessed at least 6 mm ( 1 ⁄ 4 in.) from the outer surface of the enclosure.
