kstall
kstall
elpaso
the code requires all devices be bonded to the box on which there mounted.my question is if your load center is properly grounded and bonded,and you pull a ground wire from said load center to all devices and securely fasten it to the devices do meet code requirements for proper bonding of the device?or do you still have to connect the ground wire to a screw in the box?
