JDB3
- San Antonio, Texas
Help please.
Trying to figure the size of service needed for a small church building. A "mechanical engineer" designed & wired (I was told) it originally. From the grounded (neutral) wire going up the pole riser to the power company's transformer & everything there after looks wrong to me. 3 phase service.
I could not open the lock on the disconnect to look inside of it, to verify size of any of the conductors. Looks like he then ran some multi-wire copper cable (2 runs, direct burial) in rocky ground & then cane up and went into 2" PVC (inches deep) into the 3 phase indoor panel. Triple parallel (perhaps #6) onto the panel lugs.
The structure is perhaps 2,000 square feet. It was cold, rainy, windy day when I was there, did not spend much time there.
Contacted the power company & they could just tell me that the past billing was 760 Kw hours usage for that billing period.
Approximately 150 foot run from disconnect @ road to building.
What size service would you'll recommend? {Because cost is a big factor here}
As always, thanks.
As always, thanks.
