Anybody had any experience, good or bad with [FONT="]kwik-couple rigid conduit ?
http://www.alliedeg.us/index.php?P=Kwik-CoupleIMCGRC
[/FONT]
[/FONT]
It maintains the bonding integrity comparable to couplings. But it is not clear whether it is also as liquid or gas tight as conventional tapered thread couplings. (The non-threaded part which holds the coupling to the pipe section that it came with.)Anybody had any experience, good or bad with [FONT="]kwik-couple rigid conduit ?
[/FONT]
It looks like it would also free you from the plumber's nightmare of having to disassemble the system from the far end to undo a joint in the middle.I have not personally used it, but it seems installation would be much easier. A lot of the battle with rigid is spinning a bent piece of pipe on to another. These essentially have a three piece on one end. Seems like it would be easier to install![]()
Yeah, it looks like you either use it full length or you cut and field thread the end opposite the spinner, leaving you with a "scrap" section that will just have conventional threads at both ends after you thread the cut end.I wonder if you can reuse the spinning piece on the end if you cut and re-thread that side of the conduit. I bet not, there must be some sort of shoulder that it spins against.
edit for spelling
I don't see conduit couplings as being liquid or gas tight. Conduit couplings have straight threads and they leak. Only the threads on the conduit itself have tapered threads.It maintains the bonding integrity comparable to couplings. But it is not clear whether it is also as liquid or gas tight as conventional tapered thread couplings. (The non-threaded part which holds the coupling to the pipe section that it came with.)
