Ky Test Question Again
TDCHUNT
Full load amp rating of a motor relates to what.
A) motor starting current
B) locked rotor current
C) motor stopping current
D) motor running current
Smart $
Esteemed Member
Ohio
What is your answer? ..and explain why you believe it to be correct.
If we just furnish the answer, what is the point of being tested.
roger
Fl
Retired Electrician
I agree with Smart$, give us your answer and reasoning for it.
Roger
TDCHUNT
Full Load Amps
Full Load Amps
I m thinking motor starting. It it easier to keep something running after it is started. But all the tables in sec. 430.247-430.250 give full load amps. for motors running at base or normal speeds. So I am still kind of guessing.
BackInTheHabit
Thanks for seperating your answers. It helps the eyes.:grin:
Full Load Amps - The amount of current, in amps, in an electrical circuit when the load is operating in a full-capacity condition.
Smart $
Esteemed Member
Ohio
Yes, you are.
Smart $
Esteemed Member
Ohio
:rolleyes: :rolleyes: :rolleyes:
