Try to make sure you hit alongside a stud and use one of Arlington's "One box"es. They have a lot of cubic inches and as mentioned about physical strains on plugging and twisting - it at least is attached to framing member.
Only 120v receptacles require GFCI protection.
2017 has expanded the requirements.
So what would happen if he did have to supply a 3ph receptacle?Correct.. he is lucky it wasn't a 3 phase unit. Try finding a 3 phase 30 amp GFCI breaker![]()
GFCI's won't work that way, need one common CT for leakage current detection.QO330GFI
only $600 a piece, internet search price.
Eta: given the dramatic cost difference between three phase and single, could you code compliantly handle tie 3-1 pole GFI Breakers together? Would save about 500 bucks
