PhaseShift
Is there anywhere in the NEC that requires disconnects to be labeled with their source of power? How about the load to which they feed?
Don,
Is there a section that requires that different Sources,
arriving at the same distribution point (facility panel board),
be identified ?
I can see a safety hazard in not having the different sources ID'd.
Forget about NEC references; I think a good question is why would you not label them with the panel/source they are fed from, and the load they serve?
Why only do the required minimum, i.e. NEC?
My god man, have we all become minimalists?:roll:
If you have a simple transfer switch for selecting utility or generator power and it is alread marked to indicate this and there is no other power sources why would you need any other labeling?
Kind of like a disconnect right next to a piece of equipment with a raceway between the disconnect and the equipment, with nothing else around that it may serve. What do you think most people will think the disconnect is for? Or even a disconnect mounted in or on the piece of equipment?
For the example you provide the piece of equipment may be obvious, but where is the disconnect fed from? That would need a label, and since your providing a label, then why not put the equipment number that ii feeds on there as well.
Many facilities use databases to keep track of all there equipment. It is a good practice for these numbers to appear on the designated pieces of equipment, and on any associated switches, disconnects, panels, etc.
