IRCS
- Vero Beach & Miami, Florida
Is there a section in the NEC that requires "permanent labeling" of rooftop fan equipment on a high rise building. The installer is simply using a magic marker labeling the fan number and breaker number located in the electrical room below the roof.
Also is a disconnect required for each fan?
The HVAC firm is replacing exhaust fans on the roof and is not installing a disconnect switch on the junction box of the connection. The building was built about 20 years ago. Isn't a disconnect means required for each connection?
Thank you
Thank you
