Aluminum clad MC cable assemblies are available in larger sizes now, up to 750 kcmil. I was looking for a labor rate to install the following aluminum clad types:
4#4/0 CU and 4 #250 kcmil AL
Similar pricing breakdown to Means Section 16120, my 2004 guide only goes up to #10, 4 wire (I dont believe cables of this size were available in 2004)
I just need the per foot cost to install in an overhead application, 15'-0" AFF.
If anyone has a current Means guide, can you check? Of if there is a contractor with a suitable number to use for budget purposes that would be fine.
Thanks,
MM
Thanks,
MM
