- Tennessee NEC:2017
- Semi-Retired Electrician
I was looking at a proposed panel change from fuses to breakers. The customer has a "handyman" working there and he told me he knew all about the electrical if I had any questions. He then proceeded to tell me that he had grounded all of the non-grounded receptacles. I asked him exactly what he meant and what he did. He told me that the NM was just a 2-wire and he grounded them. I asked him what he did. He told me that he got those green pigtails for grounding and screwed them to the back of the boxes and then to the new 3-prong receptacles that he installed. I asked him if he ran a EGC (grounding conductor) to the boxes. He said no but the boxes were now grounded.
I tried to explain to him that unless a ground wire was run to the box that it was not grounded. He then told me that a "good family friend" that was an electrician taught him to do this. I asked if maybe he missed part of the instructions about needing the ground wire from the panel or another grounded outlet. I don't think I got through to him!
I'm not even sure if the boxes are even metal as I didn't look at them.
If I get the job, I'm just going to tell the HO about the falsely grounded receptacles and let them decide what to do. I'll just change the panel and if they want me to correct this I will. Otherwise I'll just do the panel and be done with it.
