Wacko
New User
- Smyrna, GA
The dock at the lake house is some how electrified. Or maybe not. I hooked the branch circuit wiring directly to the metal frame of the dock and the branch circuit breaker tripped immediately.
While the kids are swimming and try to climb out they receive what appears to be a clear electrical shock.
I am a licensed electrician. I have examined the wiring thoroughly. Including an insulation test on the branch circuit wiring. There is an equipment ground wire in the conduit supplying the dock and the dock has a good earth ground.
Could static be causing this issue?
I have done some research and read where several kids have been killed by this problem.
I know this is a code forum. Just thought I would ask.
Thanks ahead.
Wacko
Thanks ahead.
Wacko
