Lamp Post Light GFCI trip
Shawnmjr
New User
Michigan
Manager
I was wondering if someone could help me with this problem I just started experiencing. I have a yard lamp post wired on a switch that trips my GFCI receptacle when switch is turned on. When I take the lamp fixture off the pole (wires still hooked up) it does not trip the gfci when switch is turned on. Once the lamp fixture itself makes contact with the pole when put back on it trips the gfci. There are no wires touching inside the fixture. Also if the lamp is unhooked from the wires it doesn’t trip, only trips when it touches the pole. I thought maybe the fixture was bad so I wired a receptacle to the wires and touched the screw for the receptacle to the pole and it tripped too. This light has been up for years and there haven’t been any changes. What could be causing this? I thought maybe a nick in the UF cable, but why would it only trip when making contact with the pole?
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Reminder to all members, if you see a questionable post, feel free to report it by clicking "Report" at the bottom left corner of the post.
