Amperess
- Palm Springs
I've got a 3 phase 225 amp load center with #350 aluminum feeders. Phase C has 10 inches of insulation melted back from the lug that needs replacing (cannot tighten or loosen) due to extreme heat. The panel is feeding 6-40amp 3 pole breakers, 6-20amp 2pole breakers (all mentioned run wall a.c.'s), 12-20amp single pole breakers for lighting and outlets. This is the desert and a.c.'s are always running. The main breaker cabinet is approx. 60 feet away.
I am concerned with how the main feed has been shaved to fit into the lugs during original install. And told that replacing that size wire with copper is too hard to do. Besides, I plan to replace the 225 amp with a 400amp/ bolt on breakers to better accomadate during full house. ( It's a hotel) And wouldn't that allow them get more use out of the older a.c. wall units?
Any advice?
Any advice?
